Old 02-12-2013, 02:25 PM   #543 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Riding it with the top off is pretty easy. Just use a gloved hand on the ground to start. It has high gearing and 6 speeds so low gear is fairly stiff about like a normal road bike in top gear. Steering is limited as the wheel will hit the chain ring and crankarms. Turns need to kept to low lean angles.
Other than that it is like riding a bike.
Arcosine has a road going liner.
veloliner.com
Noah Webster, 1787
The Following User Says Thank You to Varn For This Useful Post:
aerohead (02-16-2013)
