Old 02-12-2013, 10:43 PM   #5 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.42 mpg (US)
Originally Posted by dohcsvt View Post
On my way to work today I averaged 47MPG, which is by far the best FE ever in this vehicle. I am hoping to do better, but need some input.
You are off to a very good start. I suggest fine tuning the grille block - cover too much, then open up just enough to keep the engine from overheating. Tire pressures to max sidewall. Wheel covers. Belly pan if you feel ambitious. Get good with the EOC switch.
Really work the DWB and DWL. When you stop using the cruise control because you get better mileage driving manually, then you are ready to start learning DWL.
But don't waste time trying to redesign the fuel delivery system.
Does your car have the same engine as the base 1995 Neon? If so, that engine could benefit from a camshaft designed for efficiency at lower RPM.
