Old 02-13-2013, 12:42 PM   #24 (permalink)
razor02097
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
Originally Posted by sarguy01 View Post
I have read that. But, I need some more time to research, in depth, some of the specifics.
My current driving is pretty sane, but I don't employ any hypermiling techniques.
You don't have to hypermile, you could employ techniques as you can. If there is one thing to take away from eco driving... it is how the brake system's job is to convert momentum into heat and brake dust. Momentum is generated by the vehicle's engine which uses fuel. It would then stand to reason that using the brake effectively wastes fuel.
There are many efficiency tips you can use but your route will be different than other routes and your vehicle is different than other vehicles. Some testing and experimentation will be required.
Project Avalon: E bike build
