It was really nice today so I decided since I didn't have classes I would start putting my EV back together.
Last night my dad helped me move the Warp 9 from the basement to outside my EV. Then this morning I got the transmission out and mounted it to the Warp 9. Then I had to drill new holes on my rear motor mount because the Warp 9 has a different rear bolt pattern.
Then after lunch we used the engine hoist to install the motor and transmission combo into my Civic. It went pretty well, after a few minutes we had two of the four engine mounts bolted in. The rear mount is always difficult to do but my dad was able to help after he got home from work.
I also had to get a new speed sensor for the Warp 9. My old sensor was too small for the 1.125" shaft so I got a new sensor from Evolve Electrics with 2 day shipping and it arrived as I was installing the motor. It took 30 seconds to install as the Warp 9 was built with bolt holes for a speed sensor.
Now I have the Warp 9 installed, the axles in and the tires back on the EV. Later this week I am going to try and get more things installed, including better insulation for the heater pipe and batteries. I am really hoping to start commuting again in the next week, I just need the weather to cooperate long enough to finish the last 10%.
