Old 02-13-2013, 10:56 PM   #33 (permalink)
SpeedyCorky
also races Sportbikes!!!
SpeedyCorky's Avatar
Mo' Mon-nay! - '00 Honda Civic HX
90 day: 52.26 mpg (US)
Carbon Silver - '06 Honda Insight
90 day: 82.2 mpg (US)
the air tabs swirl the air away from the car, so that the air doesnt churn behind the car, sucking it back. so if the air is sticking to the rear window, then maybe its best to remove them from the roof (as not to disturb flow), and keep them on the rear (?!?)
as for paint job, i'm just gonna rattle can paint it all flat back. stealthy and easy to repaint
I also put 45psi in my new LRR tyres! (duh).....dealer put 30psi. my old tyre set i ran 45psi, so now comparing oranges to oranges (45psi to 45psi), it turns out the LRR tyres and proper alignment, yielded me at least 3 or 4mpg. from 52mpg average to 56 at least! results consistent with every commute to work for 2 weeks straight!
GREAT NEWS! with the use of Marvel Mystery Oil, i can get into lean burn at around 1800rpm, which works out to be about 50mph in 5th gear!!! today, driving 50 to 55mph, i got 68MPG on an ALL freeway, 35mile run. i was able to stay in lean burn virtually the entire time. the route included flats, rolling hills and 1 BIG hill.... these are MPGuino results, so i'm not gonna quite declare 100% with them, but it has always been accurate in the past, by 1 to 3mpg.
so if removing power steering gets 2mpg, and underbody aero and rear wheel skirts could equal 5mpg.... then the car might just be able to pull ~75mpg on the freeway... and i could still lower it an couple inches for more mpg gains....
the mods to come this summer i hope... averaging 60mpg over a tank looks well within reach!!! my current tank i just passed 500 miles and i still got almost 1/4 tank to go !
2000 Honda Civic HX with mild aero mods
2006 Honda Insight
MIMA, FAS, no passenger sideview mirror, race style drivers mirror, front and rear underbody aero, temporary front air dam
