Originally Posted by BrandonMods
I was curious in fabricating my own grill block for my 03 malibu. Would that result in warmer running temperatures?
It could, depending on how completely you block your grille. Recommend you have a good way of monitoring your temperature so you can keep track. A ScanGauge will do it, and a whole lot of other stuff.
When I blocked the grille on my Jimmy, it started running hot until I cut a hole for cooling air. I had to enlarge the hole once, and then that did the trick.
