Thread: propane tanks
Old 02-14-2013, 11:56 AM   #10 (permalink)
raylit20
Hakuna Matata
Avalon - '99 Toyota Avalon XLS
Take look into the common closed loop solar thermal system. A heat exchanger is used so that the heat transfer fluid from the outside tank never comes into direct contact with the water being used indoors; the propane tanks could easily be used for storage of warmed ethylene glycol in this manner.
This is an excellent article from an excellent resource on the topic. Closed-Loop Solar Hot Water | Home Power Magazine
Simplify, then add lightness.
The Following User Says Thank You to raylit20 For This Useful Post:
Christ (02-14-2013)
