Old 02-15-2013, 09:14 PM   #1 (permalink)
Jicafold
Jicafold's Avatar
Block vents on air dam?
Hello. Long time listener and first time caller. I have a 1998 Volvo V70 I'm considering an underbody panel or a lower air dam lip. The factory air dam has those vents in it where the fog lights go. So..where does the air from these go if you install an underbody panel? Does that trapped air make things worse? Should I block them off with something? Thanks.
