Old 02-15-2013, 09:21 PM   #2 (permalink)
Gealii
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
Originally Posted by Jicafold View Post
Hello. Long time listener and first time caller. I have a 1998 Volvo V70 I'm considering an underbody panel or a lower air dam lip. The factory air dam has those vents in it where the fog lights go. So..where does the air from these go if you install an underbody panel? Does that trapped air make things worse? Should I block them off with something? Thanks.
generally speaking you should just grill block the whole front end off, but watch those temps. The air would just go underneath if you dont plug it so anything you do will help as it wont be allowing as much air to go underneath, but do within the hottest temps ull see in summer or make it removable for those months
"The only real mistake is the one from which we learn nothing."
- Henry Ford
