Old 02-16-2013, 03:46 AM   #7 (permalink)
Tesla
The Truck - '02 Nissan GU Patrol ST
Originally Posted by Jicafold View Post
Well, the problem I see with that on my Volvo is that it is a turbo. So that not only blocks air to the radiator, but also the intercooler and the trans cooler. So I was considering just blocking those side vent things in the bumper.
If you are prepared to look at temps, get sensors and gauges to monitor current set up and set base conditions, then look at sealing all the holes around radiator so that all air flow must pass through the coolers.
I imagine the coolers will be set in order such that intercooler is first, transcooler second then radiator last, I suspect you will find that once you seal all holes around radiator that you will still be able to do a 50% grille block without any negative impact on the intercooler or trans cooler.
