Watching you pour the water out of the air compressor you found under the seat is sort of scary, hey?
Once everything is clean(ish), I wonder if you could borrow the battery pack from the Electro-Metro to give it a small amount of voltage at a time. First 12V, then 24V, etc. It would give things that want to sizzle a little bit a chance to, possibly without damaging them as much as giving it the full beans with its own HV battery pack right off the bat.
