Old 02-16-2013, 01:19 PM   #114 (permalink)
ncdave4life
Those must be different cells. For these batteries, KingKong claims to support a 50A charge rate and 100A discharge rate.
This is copied/pasted from KingKong's Alibaba listing (for the link go to www[dot]burtonsys[dot]com/ecomodder13610.html#2):
FOB Price: US $45 - 47 / Piece
Specifications
7.2V replacement NiMH cells for Honda Civic Hybrid
Capacity:10000mah
50A charge rate&100A continous discharge
warranty:3 year
NiMH Rechargeable Battery pack for Honda Civic and Insight hybrid cars
Apply scope: Honda Cvic and Insight 2003-2005
Voltage: 7.2V.
Capactiy :10000mah( Original 6500mah)
Continue Discharge Rate: 100A
Support 50A charge rate
Warranty: 1year
Life span: above 4 years
6 Cell per stack with both ends stainless square and hexagonal standard electric car battery nuts
Our NIMH replacement sticks have passed Vehicle test, we increased the capacity from 6500mah to 10000mah to improve the performance.
Single 10000mah D cells are also available, you can assemble the stick with our D cells by yourself.
I do see that they weren't very careful with their listing. Note that it claims a 3 year warranty near the top, but a 1 year warranty further down. (My guess is that warranty claims w/ Chinese vendors might be challenging, anyhow.)
The Yabo listing is similar, but with higher price, lower capacity and higher discharge rate. They give specifications both for individual cells and 6-cell sticks:
FOB Price: US $55 - 65 / Piece
Specifications
1.Honda Hybrid car battery for sale
2.For Honda Civic/Insight/Prius
3.7.2v/6500mAh
4.HEV level D size cells
NiMH Hybrid Car Battery Pack 7.2V for Honda Civic/Insight
Voltage: 7.2V
Capactiy: 6500mAh/8000mAh
Continue Discharge Rate: 150 ampere
Nuts and inter-connecting cups, rubber heat sealing sleeves and all necessary accessories.
Just plug and replace works that everyone can do it.
For product images, detail technical spec or any other question, feel free to contact.
Item / Specification
Dimensions / Outer Diameter (mm) / 32.2±0.07
/ Over Height (mm) / 60.5±0.2
Approximate Weight(g) / 165
Nominal Capacity(mAh) / ≥6500(IEC)
Nominal Voltage(V) / 1.2
Internal Resistance (mΩ) / ≤1.6
1.2V Discharge Capacity1.2V Cut / ≥70%
Specific Energy (Wh/kg) / ≥45
Peak Power (W) / ≥130(DOD50%)
Specific Power(W/kg) / ≥850(DOD50%)
(30C Discharge,70%SOC,0.8V Cut-off) / ≥10S
Peak Charging (15C Charge, 50%SOC, 1.66V Cut-off) / ≥10S
Max Discharge (15C Discharge, 70%SOC,0.8V Cut-off) / ≥60S
High Temperature Performance(50°C Charge/Discharge Capacity Rate) / ≥70%
Low Temperature Performance(-20°C Discharge Capacity Rate) / ≥80%
Charge Retention(30 Day) / ≥75%
Working Temperature / -20°C to +55°C
Storage Temperature / -40 to +65°C
Cycle Life(C/3 Charge,1C Discharge) / ≥800cycles
2,D Type NI-MH Battery Package(7.2V HEV Battery Bar)
Dimensions / Outer Diameter (mm) / 34.0
/ Over Length (mm) / 396
Approximate Weight(g) / 1100
Nominal Capacity(mAh) / 6500(IEC)
Nominal Voltage(V) / 7.2
Internal Resistance (mΩ) / ≤9.6
7.2VDischarge Capacity7.2V Cut / ≥70%
Peak Discharge(30C Discharge, 70%SOC, 4.8V Cut-off) / ≥10S
Peak Charge(15C Charge, 50%SOC, 9.96V Cut-off) / ≥10S
Max Continuous Discharge(15C Discharge, 70%SOC, 4.8V Cut-off) / ≥60S
Low Temperature Performance(-20°C Discharge Rate) / ≥80%
Charge Retention(30 Days) / ≥75%
