Ben I have worked on the imiev and will help if required. I would suggest that you pull up the passenger seat , remove the carpet cover and pull out the traction battery disconnect before doing much else. The inverter /dcdc and charger are all very well made and quite hermetic so i'd say you have a good chance of making it run. Best of luck!
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
