My AX with side mirrirs replaced with 2 inch convex ones.
I just cut the mirror mount down and glued them on
Everything looks tiny, even when its real close. The thing to remember is that if you can see something in the mirrors then its probably not safe to change lane. A quick over shoulder check is the decision maker.
Edit - And the manual adjustment stalks inside the car still work too
