Thread: 04 Aveo MPG
Old 02-18-2013, 10:18 PM   #1 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 40.78 mpg (US)
04 Aveo MPG
Since my truck went into the body shop after hitting a deer, I've been driving a loaner car. This is working out nicely because my insurance does not include rental car coverage.
The loaner car is a 2004 Chevrolet Aveo with 150,000 miles, worn struts, worn rear suspension bushings, 4 spd automatic, and power steering. During this time, a rear wheel bearing seized up, and I drove it back to the body shop with three wheels turning. Drove OK on snow, corners were a challenge. As of yesterday, I've put 506.9 miles on it, and put in 14.29 gallons, for 35.5 MPG.
The weather has been cold, with typical temperatures 0 to 10 deg F. The winds have been mostly headwinds, we have had several snowfalls. I would have done well to get 29 MPG in my truck. The Aveo is geared 2100 RPM at 55 MPH.
Being an ECOMODDER, I could not resist thinking about what I would do to it if...
Manual steering
Grille block
Air dam and/or front belly pan
Fix front and rear suspensions
Front and rear wheel alignment
LRR tires pumped up
Manual transmission
Kill switch
Change final drive ratio to get about 1900 RPM at 55 MPH
Ultragauge/Scangauge plus vacuum gauge
With all of the above, I would expect mid 40's for winter MPG, and mid 50's for summer MPG. The Aveo could be a pretty good little economy car. And they are available cheap.
The Following User Says Thank You to JRMichler For This Useful Post:
MetroMPG (03-18-2015)
