cost estimate so far on this fairing is as follows.
Glass csm $100
resin $100
foam $50
other $50
total $300
These are all estimates, as I've not kept track as well as I should have. Also, it must be noted that the price for CSM includes enough to do the tail as well, and I am using the cheapest available resin.
Do you have to cut out for the front wheel turning, or is there enough room as is?
I have not yet cut out for turning. I will be working on that, as well as adding an upper mounting bracket today.
