Old 02-19-2013, 08:53 AM   #8 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by Blackhatch View Post
If they are water cooled units now, that makes sense. Long overdue too.
As I understand it, the motivation for switching to water cooling isn't so much because it's "better" per se. The "modern" turbos are variable geometry, which means they have an electronic acuator attached. The electronics need the water cooling, and since the water's already required, they use it to cool the turbo itself as well. If they didn't need the coolant for the electronics, I suspect they'd have stayed with oil cooling.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
