Old 02-19-2013, 11:57 AM   #4 (permalink)
shovel
Originally Posted by razor02097 View Post
Check the transmission fluid. If it is dark and burnt the tranny is screwed anyway. DO NOT CHANGE THE FLUID IF IT IS DARK AND BURNT. Reason is the damage is done and likely the only thing that is preventing the trans from slipping is the varnish build up. If you were to change the fluid the new fluid will eat the varnish from the plates and the transmission may start to slip.
I totally don't agree with this.
Work From Home mod has saved more fuel than everything else put together.
