Old 02-19-2013, 11:02 AM   #6 (permalink)
97-civic-ex
The distributor can not be installed 180* off. The slit is not centered. If you try to install it 180* it will snap the ear off the cam and you will need a new cam. Make sure you play close attention to that to avoid issues. If it feels like you are forcing it in,... it is probably 180 out.
