Old 02-19-2013, 03:57 PM   #11 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
I have to agree, I clock about 5 psi at 60 and 9-10 at 70. I have the waste gate set a bit high at 14 and drive it at a max of 12 psi. It will pull 14 psi at half throttle. I need to get an EGT.
By contrast my vw TD gets 2-3 psi at 60.
When I put a turbo on my diesel I picked up at least 2 to 3 mpg on the highway. And that's comparing driving 55-60 when N/A to +65MPH w/turbo.
Diesel engines are nice because the more air you can cram into the cylinders the better the fuel economy and power out put will be.
If you had a boost gauge you may see why there is a fuel economy jump at the higher speeds. At 60 the turbo maybe under such light load it may not be kicking out any boost, at 65 you could be developing 1 or 3 PSI and that small change can make a lot of difference.
Water injection
Water injection can raise the boost? I thought it was to lower the combustion temp.
Noah Webster, 1787
