Old 02-19-2013, 09:36 PM   #7 (permalink)
dlb
no worries about installing the dizzy correctly. i was very careful because i wanted to mark sure i didn't wind up off a tooth (a la my old toyotas) so it was kept in position and i had no trouble reinstalling it.
ryland, are these the arrows you are talking about?
they are on the lower timing cover but they are the only arrows i could see. i can't tell which marks on the cam sprocket are supposed to match them though. i assume the portion of the pulley marked 'up' goes to the top, and the line that is located counterclockwise to the 'up' lines up with the arrow on the left. however, there is a second line on the pulley and i can't see what it should line up with. any ideas?
sorry if this sounds confusing. it's difficult to describe these things clearly.
