Just for the info if anyone is interested, probably not.. but I'll offer it anyway...
On a Honda Civic Hybrid Gen1, to reset the IMA (MCM) you have to pull the #9 fuse for 60 seconds. The #9 fuse is found in the fuse box under the hood. It's the 10A at the bottom of the 3rd column of mini fuses within said fuse box... which is on the right side of the motor compartment forward of the steering column and north of the 12V battery.
Sure... your welcome. Glad to help... Whatever.
