That is incorrect - our cells give 6.8Ah nominal at 150A and will give well over 7Ah at low discharge rates, hence their 8Ah rating. When I saw your sticks coming in at 6.1 - 6.3Ah at only a 25A rate, I was not interested. I tested 5 of them and none of them gave 6500mAh. When I asked you about this, you said it was normal. I also assume the 5 samples you sent me are the best of the best, which isn't exactly encouraging either.
Don't play games with us - just confirm or deny whether you use rejected cells. You've all but admitted it by saying that you work closely with my manufacturer, yet you won't say my claims are false.
Your other points are valid and true, but that's not what we're discussing here. I assume most people in this thread have already seen the analysis of the 10Ah cells that Mike and I did. We're not questioning the ability of the construction of our cells. We're questioning whether your sticks are fit for HEV use.
