Old 02-20-2013, 05:30 AM   #136 (permalink)
Eli81
Originally Posted by microhybrid View Post
About capacity, we use 6500mAh cells, and of course not rejected cells for sure. And the reason why we don't use 6800mAh or 7000mAh capacity? The reason is the same why Panasonic don't make cells larger than 6500mAh for hybrid car while they even can make 11Ah cells(both of us can), more capacity means shorter calender life, i have explained above this issue is about the thickness of separator, we evaluate and adjust the feature of calender life and capacity to a both accepted level, i think you could understand that if you are familiar with electric-chemistry.
At last, you mentioned that your battery is 6.8Ah capacity at 150A discharge, have you tested about it? Because i know even Panasonic can't make battery at such a high level, or even not close, that is far beyond the current ability of the world's NiMH battery technology, i can even tell many more basic concept mistakes in your judgement, i think you are misled by your "professional" supplier.
Sir, please don't insult my intelligence. I am well aware of everything you mentioned having to do with the separator (and plate) thicknesses. Obviously it's possible to produce NiMH D cells of varying capacities and current carrying capabilities. More capacity means less current - it's always a trade off between capacity, current and longevity.
Of course I have tested my cells. I have mountains of data. I've tested them at up to 70A of charge current from 0% to 100% SoC and at 160A of discharge current from 100% SoC to 0% SoC. I've tested them to 210F. I have cells that are nearly 2 years old - the oldest ones in existence.
Your own specifications state that your cells can carry 150A of current, so why would you question whether mine can? You're the one claiming that our cells are the same. Very confusing.
Anyway, let's end this now. I'm not going to continue arguing with you. I've stated my side of the story and I guess you've stated yours, so there we are.
