Old 02-20-2013, 08:58 AM   #4 (permalink)
razor02097
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
As a person that owns a motorcycle with a 3 gallon fuel tank let me say that it is VERY difficult to get accurate fuel economy calculations. After 120-130 miles I put about 2 gallons in. I have to look at a physical reference inside the fuel tank to determine when the tank is full. The smaller the fuel tank on a vehicle the more the fuel economy calculations can vary in 2 ways... range and volume. Here is an example....
I ride my motorcycle 120 miles then fill the tank with 1.925 gallons. That works out to 62.3MPG right? I ride another 120 miles and fill the tank with 2 gallons even that is 60MPG which is a 2.3MPG difference.
I drive my car 320 miles then fill the tank with 10.925 gallons. That works out to 29.3MPG. I drive another 320 miles and fill the tank with 11 gallons even that is 29MPG which is only a .3MPG difference.
Both vehicles the second scenario took .075 gallons more however you can see since the motorcycle had less range and took less total fuel that tiny amount of fuel made a HUGE difference in fuel economy calculations!
.075 gallons is about 1.2 cups... I don't know about you but looking in a 2" filler port on a fuel tank I can't tell if I've put 1.2 cups more in than the last time... I would assume the manufacturer has much more accurate means of measuring fuel economy than the average Joe... However I wouldn't discount the average Joe because we all know OEM will inflate fuel economy numbers...
Project Avalon: E bike build
