Old 02-20-2013, 09:09 AM   #2 (permalink)
razor02097
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
Drain all of the bad fuel out and replace with fresh fuel. Small engines are sensitive to varnish... Do not use additives to try to clean out the carb. It is a waste of money.
If you store small engines put sta-bil in the last tank then run it through. That is the only product I have found that does what it says.
Project Avalon: E bike build
The Following User Says Thank You to razor02097 For This Useful Post:
stillsearching (03-01-2013)
