Old 02-20-2013, 10:51 PM   #16 (permalink)
trooper Tdiesel
live, breath, Isuzu-Ds
trooper Tdiesel's Avatar
puddle jumper - '93 Suzuki sidekick base model
energizer bunny - '86 isuzu trooper base model
Clifford the big red dog - '84 GM S-10 durango
4wd E250 and E350 vans are out there in small numbers.
but the 4wd set up puts a fare dent in mpg numbers...
for modest off roading on just rock roads, id say run as is or add a LSD of some sort.
there where for many years 3 sizes of full size van made by ford and dodge mabe GM to.
a 9, 12 and 15 passenger and there cargo van versions..
the 9 passenger is always on a 1/2 ton frames and has a shorter wheel base and can get the best mpg do to being the lightest.
also for the 1/2 ton gearing choses range from some where around 4.55s all the way to 2.73 gears. at least in the ford vans that is....
when pared with a manual trans and a good ol I-6 engine, mpg can push 20+ when driven at modest speeds.
sadly some time in the late/mid 80s is the end of full size vans having a manual trans and or I-6 in the USA. with the exsepshon of the fords, they had a I-6 tell about 1996 the tried and true 300-6
hears one of the last ones, by dodge they had a 3.9 V-6 or a classic 5.2L 318ci V-8 both getting above common mpg,
the 3.9L is bolted to a 3sp auto where the 5.2L has the 4sp auto, thus mpg ratings are very close to the same.
http://www.auto123.com/en/dodge/ram-...rid=1021502001
1 86 T\D trooper with rare GEN 3 rods TRANS FIXED NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
The Following User Says Thank You to trooper Tdiesel For This Useful Post:
nikolasbarrios (02-21-2013)
