"My reasoning behind a WAI is that warm air would help the engine warm up faster and stay above 195 degrees Fahrenheit"
Every car's cooling system makes sure that the car stays at operating temp after it's warmed up by using a thermostat. If you're dropping below what your t stat is rated at, then you have a bad t stat or you've been coasting down a hill too long.
1988 rx7 convertible. Streetported, racing beat header and presilencer replacing all 3 catalytic converters. Atkins 6 port sleeves. K&N cone filter intake. 22mpg average, 27mpg max. Spreadsheet (updated regularly):
https://dl.dropbox.com/u/5310442/198...%20mileage.xls
