Originally Posted by t vago
Maximum rated power would go down, but who cruises down the highway at wide-open throttle?
I've seen about a 5% improvement in FE from raising my truck's intake temperature 50 F above ambient.
How so?
More power means you can get up to speed faster with the same shift points.
5% is a good improvement, and worthwhile. I'm curious how much this mod helps with an already warm engine going down the highway - in other words, if you took the cold start out of the equation.
