Old 02-21-2013, 03:25 PM   #2 (permalink)
razor02097
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
You could check out my project BEV. I'm planning for a 50 mile range on my LiFePo 48V pack and it will weigh HALF of what the other SLA E-bike weighed. My budget was $1500 which included everything even helmet and flashy lights.
Weight of lead acid batteries are no joke... an 12V 18aH battery is 14lbs... If you have a 48V system you are talking about a 56lb battery pack! I know that doesn't seem too bad but it isn't until you try to lift it that you realize that is a lot of weight...so swapping out an SLA battery isn't really feasible.
In your situation and only if you are stuck on electric... an electric motorcycle might be a better alternative. I only say that because with a motorcycle frame you can put on more batteries for longer range and you don't have to pedal ever. As for budget... If you could get a complete motorcycle very cheap or free it might be possible to convert it for $1000... You would have to get used batteries and a cheap conversion kit.
Otherwise you should be able to find a small older motorcycle for under $1000.
Project Avalon: E bike build
