Old 02-22-2013, 04:40 AM   #21 (permalink)
trooper Tdiesel
live, breath, Isuzu-Ds
trooper Tdiesel's Avatar
puddle jumper - '93 Suzuki sidekick base model
energizer bunny - '86 isuzu trooper base model
Clifford the big red dog - '84 GM S-10 durango
in short....
fords are the most common to be converted to 4wd
GM is 2nd
dodge is very seldom swapped over.
biggest size van with lowest cost to drive with a OE gas engine and auto trans?
"its the most aro" thus an advantage in that respect.
the 90s/2000s dodge 1 ton 15 passenger with OHV 5.2L 318-V8
they can pull 20+ mpg on the open road, oddly good for there size.
a ford van with the 4.2L V-6 would be close or better mpg but no where as big as far as cargo space as there mostly in 1/2 tons the 3/4 and 1 tons got the V-8s and V-10.
unless you convert a newer gas van to manual trans. that's about as good as it will get for a gas engine.
after that its diesels,
first is this OE type swaped to a manual it would be mid 20s
there was this the 6.2L and later the 6.5L with the van model having a very rare 6.5L N\A set up in some cases.
Compare Old and New MPG Estimates
i know ford diesel vans are out there also, but being 1 tons there not listed on the mpg site...
after that there's not very many OE diesels.
putting a 80s ford 6.9L or 7.3L IDI N\A with manual trans in to a 90s dodge van.
or a cummens 4BT or isuzu 4DB1 or 4DB2 all are 3.9L, around 750lbs 100/130hp, with max rpms of about 2,800
with a manual trans that could push the number up in to the mid 20s or just in to the high 20s when empty and driven slow.
a direct drive trans with a final gear in the 2.73/3.55 range would help up the mpg. over drive trannys wast more then a direct drive trans does when in high gear. for as long as you have a final gear that makes up for not having the O\D gear.
1 86 T\D trooper with rare GEN 3 rods TRANS FIXED NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
