Old 02-22-2013, 08:39 AM   #15 (permalink)
Cobb
If its not slipping or anything, dont touch it. I had a ford e250 I did all the basics to including new fluid and filter. Within half a tank of gas the tranny started to slip and it was a real hand full to drive. The fluid was black and smelled like onions.
Originally Posted by razor02097 View Post
Check the transmission fluid. If it is dark and burnt the tranny is screwed anyway. DO NOT CHANGE THE FLUID IF IT IS DARK AND BURNT. Reason is the damage is done and likely the only thing that is preventing the trans from slipping is the varnish build up. If you were to change the fluid the new fluid will eat the varnish from the plates and the transmission may start to slip.
