Originally Posted by ksa8907
I think a big reason chrysler didn't use a smaller diesel instead of the v6 gas is that chrysler is dropping their 5 or 6 current v6s for just the 3.6 which will make that engine very cheap per unit. Also, consider the programming needed for a new diesel where they could just borrow from the durango and jeep.
I guess you missed the part about the new 3.0L V6 diesel in the Ram1500
Originally Posted by pete c
I disagree. There are plenty of people out there who look quite closely at price and mileage. A modern big 4 banger makes perfectly acceptable levels of power and they can be built considerably cheaper than similar V-6s. The only thing they give up is a little bit of noise and vibration. Those concerned with this will lively want the gas V-8.
Really? You people are unhappy because it for a 3.0L V6 instead of a 3.0L 4cyl?
LOL
Originally Posted by cRiPpLe_rOoStEr
Since a 4-banger is less expensive to manufacture, would eventually lead to a more competitive purchase cost, which could also get attractive to some customers who currently get the V6 gasser. But the 4-banger used in the ProMaster is not so attractive at all with its 160hp, same rating of an ISF3.8, but with much lower 295lb.ft. torque...
Do you have access to Fiat's internal accounting of manufacturing costs? Can you send it to me, I would like to take a look at it too.
The Promaster diesel makes 174hp, 295torque.
The Ram V6 diesel makes 240hp, 420 torque.
In termes of performance they are worlds apart.
