Old 02-22-2013, 01:27 PM   #71 (permalink)
Josh8loop
Definately a Modder!
Originally Posted by Demolite View Post
After a long time I'd like to share some things i noticed with my system. I recommend you don't use straight coolant to coolant transfer, the expansion system is very hard to do and the pressure of the cooling system doesn't stay in normal limits. Core plugs started to leak and the Uno's head gasget blew, propably as a result of coolant leakage. I suggest using insulated tubing to transfer heat and a pump in the system makes controlling and transferring heat quicker.
Did you mainly have issues since you effectively increased coolant system volume without providing adequate expansion volume? I have recently been reading about this on CAT engines. They mention the coolant volume vs. air expansion space needed to provide shutoff after boil protection. I am actively working on my thermal storage setup that is Dewar based and want to make sure I learn from your mistakes.
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 45 MPG City with the 01M, 5-speed 60+ MPG City. Nokian Entyre Low RR Tires. Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread...=306799&page=4
