Old 02-22-2013, 04:17 PM   #22 (permalink)
Shortie771
Eco Sol
Shortie771's Avatar
Well, what trooper Tdiesel said was a bit confusing to me....
As far as vans go, if you want a Ford here are your options (not including the E-series or the Econoline). The vehicle links will take you to that model's Wikipedia article so that you can see the different variants of the model, the different engine/transmission combinations and also the available cargo room (if listed). The links to the mpg are from owner's trip/tank logs, just like we do here. Be sure you sort by the engine type of your preference...
Aerostar - MPG
Freestar - MPG
Freda aka Mazda Bongo - MPG Freda/Bongo
Transit - MPG. Be sure to sort by engine. There are a lot of available engines for this van listed.
Windstar - MPG
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
