Part of what i've wondered is whether pulse and glide is good for reliability even under normal conditions though. >_> It's one thing that's kept me from trying it yet on my high mileage normally babied vehicles, saving $500 a year on gas doesn't pay for a new transmission... i've wondered whether the savings in gas outweigh the potential for increased repair costs over the long run. Even just the endless engaging and disengaging of the clutch I would think would wear it out - mine last almost 200k miles when "average" is said to be 100k. I don't think i'd like putting in one every 40k.
High power output combined with heavy weight is the 2nd hardest stress you can put on parts. (the hardest are shocks, ie suddenly losing then regaining traction, stabbing the throttle then dropping it then stabbing) I would think that if the machinery were overbuilt enough it would work better, perhaps one could build a deliberate P&G vehicle with an overstrong powertrain? (one downside there being that large heavy parts take more parasitic drag to turn normally as well, hmm)
G-fumes can you expand? You pulsed up to 45 then glided down to what speed roughly?
piwoslaw - could you expand with some more details? I'm just curious how it worked for them.
It would seem that its an area worth some more research in any case - I may very well end up doing that kind of research with my Project Tow10k when I get it together. I'm deliberately choosing to make it out of 'cheap' parts that if I lunch a few it's not the end of the world, like a transmission maybe costing $400 to replace instead of $4000, same with rear axles, etc.
