Old 02-23-2013, 12:55 AM   #8 (permalink)
kirkerik
True for the kumho solus...
Originally Posted by mcrews View Post
not sure were you got your weight but it's way off.
the tires (just tires) are 2lbs apart.
weight issue is a mote point.
the tire revolutions are 734 and 716. that barely 3%. Statisticly you need 5% + to really be able to notice any difference.
I was comparing a "P" tire to a "LT" tire. The tire brands i was looking at had only one preferred size in each of the two classes - P, LT. I guess i was comparing apples to oranges in a way? So depending on brand i may be able to get the weight down.
Im looking for an All Terrain tire BTW. it kinda limits the options a bit.
Thanks for the info on statistics. I bet i might be able to "just" tell a difference 'cause my truck lugs a bit now with the 235's.
