Old 02-23-2013, 01:56 PM   #3 (permalink)
aerohead
aero= 35-45%
*With less than a foot added for a nose 'cleanup' a 'comprehensive' streamlining kit should net you around a 35% HWY-only mpg improvement.
*If your willing to put up with 3-feet of boat tail on top of that,you could see a 45% HWY-only mpg improvement.
*A little longer tail might net you a bit more.
*Gearing will push your mileage higher.
*I know nothing of what radials might be out there which might show up,mileage-wise.
*Radials,O.D.transmission,and taller rear axle pushed my '62 Dodge D100 from 11mpg at 50 mph,to 16 mpg at 65 mph.
*A nose,full wheelcovers,,front gap-fillers,rear skirts,fan delete,and aero shell got it to 21 mpg at 65 mph,nearly doubling the HWY mpg.A belly pan would have pushed it over 2X.
Rings are shot and I've probably got a burnt exhaust valve on one cylinder.She'd no doubt do better with a fresh engine.
*The T-100 will do 36.5 mpg @ 65 mph with the 30" boat tail.
*31.8 mpg @ 75 mph.
*Originally,she was returning 23.3 mpg @ 70 mpg.
*No mods have been done to truck other than aero.
slowmover (02-24-2013), stillsearching (02-27-2013)
