Welcome. Not sure if you have done this already, but synthetic oil at your next oil change might be a consideration. Two differentials, a transmission, and a transfer case all spinning makes for a lot of sources of friction, you may consider servicing them with synthetic fluids next time they are due as well. Being a regular cab with a 5 speed, I am guessing your truck has steel wheels, not alloys. If your windy rural driving has a lot of stops, finding some used factory alloys might be something to look at. Reducing your un-sprung rotational mass would help with a lot of stop & go driving. Used factory alloy wheels are probably fairly inexpensive, being the first thing someone usually takes off when they decide to mod their 4x4.
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
