Thanx, Darin,
I took your advice & did it without doing another set of "A" tests beforehand (or after, because I was so pleased, I didn't wanna remove it!!!) The weather was similar to the way it was when I did the initial "A" tests the other day, and as you suggested, don't think I need to "prove" it in rigorous testing - - - - I
know it works!!! (see thumbnail below)
Revisiting my initial "to do list", starting to have some progress.
Originally Posted by wmjinman
I'm trying to gather my thoughts and figure out where to start in modding.
1) Air up the tires to? 155-80/13 Can they handle 60, I wonder?
>>> Put them at about 45 (sidewall sez 44 max), and they look & feel pretty "pumped" at 45 <<<
2) Front grille block with black duct tape - nicer one later
>>> VERY pleased with this. Gained 2.467 MPG; from 46.95 to 49.41 at 55 MPH <<<
3) Fuel injector kill switch for better EOC-ing
4) Hand throttle control, so I can drive long distances easier
5) Rear wheel/4-wheel alignment. Outsides of rear tires are wearing badly
6) Engine/oil pan heater. Not super-cheap, but it's winter & I want MPGs!
7) Rear fender skirts - cardboard first for A-B-A testing, then nicer - maybe
8) Full belly pan
9) Front & maybe rear wheel covers and/or fairings/spats
10) Kamm-back/partial boattail
11) At some point by about now, I'll need new tires - will try to find LRR
12) When the next oil change is due, go to Mobil-1, 0w20
Oh, I was so pleased with the grille block results I decided to do a pair of runs (northbound & southbound) at lower speeds. I did it between 35 and 40 MPH and averaged 61.95 MPG according to the ScanGauge. I almost did another one at between 40 and 45 mph to see if I could hit 60 mpg at that speed, but didn't due to the time.
But this time, I'm much more confident than I was with my original 60+ mpg result, because the ScanGauge has been re-calibrated a couple times, and I think I'm finally getting it "zeroed-in" (adjustments are getting much smaller)
