you can use a stock d16y8 engine harness. tie the vtec oil pressure switch into the 16v vtec wire and just run wires from the ecu to the 2nd vtec, egr valve, egr control solenoid and econo light. i have the ecu pin outs to do that if your interested!! let me know...
