Originally Posted by scottied15
you can use a stock d16y8 engine harness. tie the vtec oil pressure switch into the 16v vtec wire and just run wires from the ecu to the 2nd vtec, egr valve, egr control solenoid and econo light. i have the ecu pin outs to do that if your interested!! let me know...
I have wiring diagram except for the econo light. Whats the pinout location for obd2b and how do I wire it? Does it output a negative or a positive signal from the ecu pin?
