Old 02-24-2013, 04:48 PM   #2 (permalink)
cRiPpLe_rOoStEr
As long as the driveline is OK you can either try to save the whole car, enjoying the opportunity to aeromod its body, or to swap it into another small car.
If you'd try to save it, I'd recommend you to cut its rotten parts away, repaint it to keep all the sheetmetal covered by the rustproofing primer and some paint, then patch it with fiberglass.
