Thread: Low cost BMS
Old 02-24-2013, 05:53 PM   #92 (permalink)
kovgab3
You are totally right.
However, if you have to replace 1-2 cells in your pack, then you might think other way about the necessity of the 5A dissipating modules
An other "reason" can be if your charger can not decrease the current on an outer signal. If you have to switch it off when the first (old) cell reaches the limit, then the new ones will never get charged to their capacity.
