Good job with that truck! Did you know if your hood can have more degrees? some car just have 2 arms with 2 bolts per arm, in the cars that i see it can be done, if you give more degrees to the hood the windshield will have less ''crash'', also you will have a ''hole'' and there the air will scape from the engine, if you have your grille fully ''blocked'' maybe it will not be so good. Good luck!.
