I also suspect the master cylinder for the clutch. I had one fail recently making my worn syncros feel worse. Instead of true double clutching, try double pumping the clutch just before shifting. This was able to build enough pressure to shift on mine before I replaced my master. Mind you this is just a test. If it is that bad, that you need to pump up hydro pressure to shift it is time to replace.
