Old 02-26-2013, 11:29 AM   #47 (permalink)
HypermilerAX
HypermilerAX's Avatar
AX - '95 Citröen AX
307 - '04 Peugeot 307 SW
Some pics of my wheels. One has already a full cover for testing.
I have also mounted a device to measure accurately my fuel consumption. I have 2 flowmeters, one on the supply line, one on the return line and a unit subtracting the 2 values. It gives an incredible 0,1 mL resolution. That makes a 0,01 l/100 precision on a one-kilometer part and 0,001 l/100 on 10 km. Next step is to calibrate it : fillup, burn 40 L and refill. At first view, the flowmeters are 30% off (overestimating).
Then, the plan is to put the car in its original configuration and do FE tests at 90 km/h on a highway stretch and then to implement a new mod mod each time (the first one will be the changing the 5th gear ratio).
ID:	12533   Click image for larger version
ID:	12534   Click image for larger version
ID:	12535   Click image for larger version
Citroën AX 1.5 D 430.000 km
Peugeot 307 SW 2.0 HDI 136 195.000 km
