Old 02-26-2013, 11:41 AM   #9 (permalink)
Blue Angel
Blue Angel's Avatar
Previous Car - '12 Chevrolet Cruze Eco MT
Team Chevy
90 day: 44.29 mpg (US)
535d XDrive - '16 BMW 535d M-Sport
Ever thought of using some type of modelling clay to make the shape of the insert, then use that to make a mold? You could produce a light weight, tight fitting piece from fiberglass or something similar.
This might be a bit more work than doing a one-off from rigid foam insulation, but the easy sculpting nature of modelling clay might produce a nicer final product. Not to mention, if you screw up with clay you just add a bit of material back on and re-work.
This is how most surfaces are defined in the studio when styling a car, but instead of pulling molds the body is digitized and modeled in CAD.
2016 BMW 535d
4100lb XDrive Eco-Yacht
