Old 02-26-2013, 07:01 PM   #68 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
potenza, one thing to keep in mind is the difference is fuel injection systems. gasoline fumes performed his on a obd0 system i believe. yours is ob2 so maybe the way that ecu works might have somthing to do with it. i have no in depth experience with honda obd2 ecus so i wouldnt know for sure.
fuel maps are probably important for it to run ok. but honda didnt make an 8 valve head after 95 so you couldnt really swap ecus to find out. if it were obd1 you could swap a cx ecu (p05) that engine came 8 valve. or obviously the hf ecu if it were obd0.
