Old 02-26-2013, 08:23 PM   #13 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
4 more options:
You can try applying a second coat to the first.
Try stretching some polyester cloth over the opening. It can be heat shrunk then make your part over it with composite and epoxy.
Using a similar technique make a mold from some layers of duct tape.
Get some two part foam You mix it just before you use it. It cures hard.
Noah Webster, 1787
